exhaust manifold temperature
srokag44
Post by srokag44 »
One of my exhaust manifolds is running much hotter than the other. Is it safe to connect a garden hose where I put the arrow in the picture to flush the exhaust and riser? Is it ok to do this without the engine running or is there a risk of water getting into the exhaust ports?
akwalker
Re: exhaust manifold temperature
Post by akwalker »
DON"T DO IT. You are correct, there is a risk of water ingestion. Better to remove the manifold if you want to try flushing it.
1981 F-26 hardtop
"Gracious Lady"
And water won't do it . I like using rydlymemarine
http://www.rydlymemarine.com/
gordd
Post by gordd »
prowlersfish wrote:And water won't do it . I like using rydlymemarine
Hey prowlersfish , how would you use it in exhaust manifold . Om my 318 starboard side experiancing same thing , running bit warmer then port side . I figured maybe there was nest in there as did find some straw tail end .
You have to rig a way to recirculate it . Its a lot safer then many acids . but still us caution .
