The prowlerfish transom door
Hey Paul how did that transom door turn out? Pics?
- DOUGNASH
Re: The prowlerfish transom door
He did finish it.
There is a thread somewhere with a couple of OK pictures
But we need like 5 or 6 good shots from different angles, just sayin
This is a project I definitely want to do...
Notice anything else ???
- completed transom 3.jpg (129.16 KiB) Viewed 4745 times
Did you also install the hawse holes, not sure if right name. Also the boat name is changed from Prowlerfish
- Stripermann2
The Hawse piping is factory on most F36's. I've never known Paul's boat name to be anything other than, "U Never Know".larryeddington wrote:Did you also install the hawse holes, not sure if right name. Also the boat name is changed from Prowlerfish
Stripermann2 wrote:The Hawse piping is factory on most F36's. I've never known Paul's boat name to be anything other than, "U Never Know".larryeddington wrote:Did you also install the hawse holes, not sure if right name. Also the boat name is changed from Prowlerfish
Yes
wrong
kind of wrong
correct
I installed the Hawse pipes thu the transom , Trojan never put them there , they did however put them through the top above the cleat on the F36 (and F30 ) . Boat was never called Prowlersfish or prowler . However my last 4 boats where prowler .
I also used much larger hawse pipes so the shore power cords would go through .
- You can see the stock Hawse pipe here on a F30 CM F36 is in the same area
- my old f30 1.jpg (83.52 KiB) Viewed 4707 times
- Custom Hawse Pipe install
- completed transom 2.jpg (62.13 KiB) Viewed 4707 times
- Stripermann2
Yeah, hawse pipe from top....Paul's boat boat was probably called something like...My Therapy in it's previous life, or something silly like that no doubt.
Your rihgt on the old name well 1 any way
My Therapy was one name Bad Boys was another .
Almost got called prowler but the bater half said NO , Then almost call it the MISS MADISON after my grand daughter . BUT and this a qoute of a 3 year old when I told her was going to name the boat Miss Madison " NO THATS MY NAME !!!! " So thats how U never Know came about .
Once there was a boat called GEORGIANA ....
- Stripermann2
Yeah, they sold it then bought a boat named, My Therapy. Small world...!prowlersfish wrote:Once there was a boat called GEORGIANA ....
small world for sureStripermann2 wrote:Yeah, they sold it then bought a boat named, My Therapy. Small world...!prowlersfish wrote:Once there was a boat called GEORGIANA ....![]()
And they sold GEORGIANA to a guy that needed therapy .
- Stripermann2
Check Mate Paul!!!
Jamie , I forgot , But the first name of my boat
1st Irish Wake ( small world again)
Marleo III
My Therapy
Bad Boys
U N K of course
Marleo III
My Therapy
Bad Boys
U N K of course
- aaronbocknek
um, jamie, can you explain the avatar? just curious. interesting though.
did you catch my thread on the impromptu raftup? a fun time was had by all. even phil.
It's a yearbook photo
