F32 hght wght
F32 hght wght
I just bought a 1985 F32. Does anyone know the height and weight? Boat has Twin Chevy 350s.
Re: F32 hght wght
The spec sheet from Trojan says, height from waterline to the top of the flybridge is 12' 8", draft is 30" and weight is 12850 pounds. I would take the weight with a grain of salt because I think that is a little low. Hope this helps.
Trojan has been sold
Au Gres, Michigan
Au Gres, Michigan
- Commissionpoint
Re: F32 hght wght
I agree the weight in the specs is probably a bare dry weight and as such is a little low.
12'8" to the waterline is with the masthead. If you drop it I think you get to 11'9" IIRC. Slightly less than that if you feel like taking the windscreen off the bridge as well.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Re: F32 hght wght
I haul mine over the road and had to check a bridge on the way the first time, boat hauler said i need 14ft and shes 13k lbs
- ready123
Re: F32 hght wght
If you take the windscreen off make sure to remove the shifters and steering wheel as they stick up above the bridge surround as does the helm console. If you are going that far just unscrew the bottom of the bridge console and lay it down.... no need to disconnect steering hydraulics or other cables.Commissionpoint wrote:I agree the weight in the specs is probably a bare dry weight and as such is a little low.
Re: F32 hght wght
Thank-You one and all for the info.
Re: F32 hght wght
Where are you moving it to and from ?
