It looks like I have a pair of 16x14 props on our F-32. Merc 230's with 1.52:1 reduction. Would that be how it was new? What are other F-32's running?
Thanks!
Another prop size
- Diverted Income
Another prop size
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
Re: Another prop size
Trojan ,lists 16x15 3 blade w/small cup .for your boat . So someone may have gone down in pitch . As most boats come pitched for a light boat , droping some pitch off can be a very good idea . Unless your turning well over the rated rpm I would not go back to factor spec .
- Diverted Income
Thank you for the confirmation!
Paul what does the factory say on props for my 84 midcabin with 270s.
Mid cabin ? Did you buy a 10 meter and not tell melarryeddington wrote:Paul what does the factory say on props for my 84 midcabin with 270s.
Our 78 with mopar 360's at 250 HP came with 16x16 according to original paperwork......at some point it got changed to 16x barely 14, was way too much rpm for no speed......I had the props tuned balanced and re pitched to 16x15.....much better for us now........
