Moderators: BeaconMarineBob , Moderator , BeaconMarineDon
rossjo
Posts: 2799 Joined: Tue Nov 08, 2005 2:48 pm
Post
by rossjo » Tue Jan 04, 2011 9:21 am
_________________________________________________________________________________________________________
ENGINE MANUALS __________________________________________________________________________________________
http://www.correctcraftfan.com/reference/manuals.asp
> Chrysler LM318, M440 Marine Engines
> Ford Interceptor Marine Engines
> Ford 302 & 351
> Crusader 198
> PCM
> Velvet Drive Installation and Service Manuals
> Morse Controls
> Teleflex Steering
VELVET DRIVE SPECS, RATING & MANUALS ________________________________________________________________________
Velvet Drive 71c-72c Series (Straight Drive) :
http://RNR-MARINE.com/TROJAN/Borg-Warne ... _Specs.pdf
http://RNR-MARINE.com/TROJAN/Borg-Warne ... atings.pdf
http://RNR-MARINE.com/TROJAN/Borg-Warne ... Manual.pdf
Velvet Drive 5000 Series (Down Angle Drive) :
http://RNR-MARINE.com/TROJAN/Velvet-Dri ... ochure.pdf
http://RNR-MARINE.com/TROJAN/Velvet-Dri ... Manual.pdf
WIRING COLORS ___________________________________________________________________________________________
ABYC Standards:
Marine Wiring Color Code - Direct Current Systems Under 50 Volts
http://www.glen-l.com/weblettr/weblette ... iring.html
http://www.ftkltd.com/Boat%20Wiring%20a ... 0Codes.htm
OUTBOARD MOTORS:
rossjo on Mon Mar 21, 2011 10:26 am, edited 2 times in total.
Captain Ross,
2009 Trojan Boater of the Year
Posts: 12727 Joined: Sat Nov 05, 2005 6:56 pm
Post
by prowlersfish » Sat Apr 29, 2017 5:17 pm
Packing info
1" uses 1/4" packing
1 1/8" shaft uses 3/16" packing
1 1/4" shaft uses 1/4" packing
1 3/8" shaft uses 5/16" * packing NOTE See updated info below 7/9/18
1 1/2" shaft uses 1/4" packing
1 3/4" shaft uses 1/2" packing
2" shaft uses 3/8" packing
2 1/4" shaft uses 7/16" packing
2 1/2" shaft uses 5/16" packing
3" shaft uses 9/16" packing
* On the F36 conv. Trojan calls for 1/4 packing . Buck Algonquin calls for 5/16 . It is my belief both sizes will work without issue . Thank you
