Posted: Mon Aug 02, 2010 11:13 pm
That will be much better then the way it was , sombody way back when got it wrong.
Call BEACON MARINE @ 609-713-4602 -- For QUICK answers to your Trojan questions
https://trojanboats.net/wforum/
Yes, the 'mounting plate' (flange is the correct term) portion of a rudder port mounts on the inside of the hull, with the 4" long barrel extending down thru to the outside of the hull. The barrel section of the port is important as it supports the rudder post. Your rudder port is missing this barrel portion, but it definitely used to have one.kickervr15s@aol.com wrote:thers not a plate on inside but i am taking all of it out and putting stuffing box to inside and plate to outside
