Re: 6.5 onan
Posted: Fri Dec 27, 2013 10:27 pm
140 raw water cooled 180 fresh water cooled ( uses coolant ) .
9
9
Call BEACON MARINE @ 609-713-4602 -- For QUICK answers to your Trojan questions
https://trojanboats.net/wforum/
Thanks! that is what I was thinking. Use 140* for Mississippi cooled. This one had 180* stats that were plugged up. Go figure, no strainer either. Correcting that too.larryeddington wrote:mine is lake cooled and uses 140 same as Chrysler engines. Bob at Beacon explained that the higher temp t stats would cause adverse reaction with salt water in the engine so the 160 to 180 are fresh water (antifreeze in raw water heat exchanger) at least with Chryslers. bet same for gennys.
The concern is that higher temps increase the rate of salt depositing on all surfaces it comes in contact with and it also promotes crystalline bridging. In a short time, it would cake up the inside of the block and cooling system components. The fix, or at least the way to prevent deposits from forming as quickly is to run at a lower temp however running a cooler engine has it's own set of drawbacks.larryeddington wrote:.....the higher temp t stats would cause adverse reaction with salt water.....
What are the drawbacks of running a cooler engine? I don't believe my boat has a thermostat in it since the hottest it seems to get is 105F. I replaced the gauge and sender, so I know the temperature reading is correct.Big D wrote:The concern is that higher temps increase the rate of salt depositing on all surfaces it comes in contact with and it also promotes crystalline bridging. In a short time, it would cake up the inside of the block and cooling system components. The fix, or at least the way to prevent deposits from forming as quickly is to run at a lower temp however running a cooler engine has it's own set of drawbacks.larryeddington wrote:.....the higher temp t stats would cause adverse reaction with salt water.....
Engines are designed to operate most efficiently within a window of operating temps. Low temps increases fuel consumption, and they don’t promote burning off moisture in the oil. Water in the oil combined with combustion by-products produce acids harmful to engine components. Oils and their lubricating properties are designed to be most effective within normal engine temp specs, so are the oil filters. Cold running prevents proper expansion of engine components like pistons, rings, etc. which is needed to bring clearances to normal spec while running to promote proper combustion and minimize component ware. Seals are also designed to run at normal temps and become more effective at such. Cool temps also cause higher soot levels and fuel dilution,…... 140 degrees for raw water cooled is already too low but necessary for other reasons so lower than that is not good. If you can’t get your engine to proper operating temp, I wouldn’t run it hard!The Dog House wrote:....What are the drawbacks of running a cooler engine? I don't believe my boat has a thermostat in it since the hottest it seems to get is 105F. I replaced the gauge and sender, so I know the temperature reading is correct.
