Dead spot on the flywheel
bolts or studs ? to do the line up..then remove studs and put in the right bolts ? :idea: :?:
Bolts , not studs I get the gear close install the bolts get it in and remove . studs work but can be a pain to remove , cutting a slot helps. But I still like using bolts in most cases. I have issues getting the gears lined up on the studs the holes are very tight on velvet drives .
