Fuel Flters - HELP
BMILLER
Post by BMILLER »
You'd think that it only had to be below the inline to the shutoff valve and the valve itself.
1978 F-28
prowlersfish wrote:Can someone show me where it needs to be lower then the carb ? Not that its a big deal to go lower .
This is the system I like http://www.marinepowerservice.com/Boati ... ctID=17568
No, and I'm not going to look :P But I'll go with every one I've seen they've been lower ... :wink: ....impo...
Seem many just above , but play it safe and mount it just be low that level .
BMILLER
Post by BMILLER »
That Sierra kit has dual inlets and outlets. Can one handle both engines? That would sure make life easier and less expensive. One filter, marine rubber hoses in from the shutoff valves and marine rubber hoses out to the fuel pumps.........?
1978 F-28
BMILLER wrote:That Sierra kit has dual inlets and outlets. Can one handle both engines? That would sure make life easier and less expensive. One filter, marine rubber hoses in from the shutoff valves and marine rubber hoses out to the fuel pumps.........?
NO . one filter for each engine
BMILLER
Post by BMILLER »
Sure wish I was still up at Fairlee Creek, I'd be able to see your setup.
1978 F-28
rossjo
Post by rossjo »
Not sure its a USCG requirement, but it just makes sense to keep the fuel filter below the carb, so it doesn't drain down into the engine when sitting.
I would agree but look at the fuel lines many are above the carb comeing from the tank , Thats why I question it .
Allen Sr
Post by Allen Sr »
prowlersfish wrote:Can someone show me where it needs to be lower then the carb ? Not that its a big deal to go lower . I could not find the requerment , But play it safe and put it just below carb level .
great filter and cheap too
This is the filter system I changed mine over to. Easy to maintain on the changing of filters and the wallet! :lol:
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Post by larryeddington »
Barry, want a picture of how mine are mounted on engine room bulkhead and I think they will be lower than carby. The way it came.
