F32 shafts length
Thanks JAV . Dave Gerrs book is a excellent resource . I should have thought of it , I have it some where .
The name of the book we are refreing to is "The Propeller Handbook" by Dave Gerr
prowlersfish wrote:Big d your take on the distance ??
I`m more in agreement with half shaft diameter. The closer it`s supported to the prop the better. Lot`s of stress there and I would prefer there be no room for wobble.
Larrys78
Post by Larrys78 »
Thanks Guys. The Mechanic called me today to tell me the shafts were to long and needed to be cut down. Of course this is after I emailed him some of your comments and the documents. There pulling the shafts as I type are being taking to a well known machine shop who works specifically on marine drive systems
1978 F-32 Knotty Playsure twin 350xl 270 Crusaders
EDMONDS WA
Teach a boy to fish and he will go hungry supporting his boat
http://s1123.photobucket.com/albums/l550/Larrys78/
larrys@wsconline.net
Good to hear
Commissionpoint
Post by Commissionpoint »
Larrys78 wrote:Thanks Guys. The Mechanic called me today to tell me the shafts were to long and needed to be cut down. Of course this is after I emailed him some of your comments and the documents. There pulling the shafts as I type are being taking to a well known machine shop who works specifically on marine drive systems
Good to hear. I want you to know that I spit shined those shafts around the strut in 20 degree weather with my fingers so you would be sure to get a good look. ;)
What would concern me most in your situation wouldn't be if you had everythiung balanced and shimmed nicely, its if something goes out of balance that the increased distance from the strut would really start to come into play. In the worst of cases I have no problem envisioning the strut starting to pull through. Good job spotting the problem and getting it sorted.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Larrys78
Post by Larrys78 »
Thanks again This forum has helped me several times. Not to many Trojan owner here in Washington. The shop that is doing all my work is one of the largest and well respected shops around I was a bit surprised I had to bring this to there attention. I think there bid to do the repower may have been a bit low. Its now 5 weeks into what they told me was a 2 week job. But that might be my fault because I told them to take there time that I didn't want a rush job.
EDMONDS WA
