New here......
Re: New here......
Went to the marina today to do a deep cleaning and all systems check before the Memorial Day weekend kicks off, also to snap a few pics that were requested of the engine room. Sorry I could not get pics of the drives and whatnot since its in a wet slip. I did however find out that the down solenoid on the starboard drive trim is shot and in a pinch had to make a jumper to trim down, I will deal with it properly after the weekend and change the solenoid. Got her all cleaned and made sure everything else checked out so I would not have to deal with much Friday evening when the admiral and I head down for the weekend.
- image(25).jpeg (134.23 KiB) Viewed 9343 times
- image(24).jpeg (105.41 KiB) Viewed 9343 times
- image(23).jpeg (116.3 KiB) Viewed 9343 times
Re: New here......
continued....
- image(35).jpeg (125.82 KiB) Viewed 9343 times
- image(29).jpeg (122.96 KiB) Viewed 9343 times
- image(28).jpeg (119.83 KiB) Viewed 9343 times
- Landlocked
Re: New here......
Welcome Trojan man!
We keep our 11 Meter at our dock in Port Duncan. I've had her, and have done the work on her, for the past 20 some years. Some of your boat looks very similar to mine. If I can help in any way, come on by. And, if you see us anchored in Woodard Hollow (Boat's name is The Primrose) feel free to come alongside.
Lake boaters skip the salt...
1985 11 Meter Sedan
1972 Newman Bassboat
1990 Cyclone Jetboat
1985 11 Meter Sedan
Re: New here......
Thank you, I will keep an eye out for ya.Landlocked wrote:Welcome Trojan man!
- aaronbocknek
Re: New here......
trojan man..... i'm GOBSMACKED at how clean your international is. you did really well on this one buddy!
Re: New here......
Hello I happen to be the new owner of this boat and I must say the boat is great. I would like to find more information on this as it did not come with any manuals but i will keep looking. I saw this posting on the forum and about fell out of my seat. I had to send the link to my wife and the boat is famous. We just purchased it on 5-16-2014 and had it delivered to our lake and only had it out once. I will need to change one prop because when it was delivered the salesperson brought a prop with him because the starboard prop looked like they hit something and broke a chuck out of the blade. We are new cruiser owners and I must say this forum may be where we ask many questions.
Re: New here......
Congrats and welcome aboard. Try Beacon Marine the sponsors of this site, they should be able to get a manual for you.
Re: New here......
Welcome to the fourm congrats on the boat and dito on what Big D said .
Re: New here......
<never mind>
Re: New here......
Thank you and I will try to check with them.Big D wrote:Congrats and welcome aboard. Try Beacon Marine the sponsors of this site, they should be able to get a manual for you.
Re: New here......
Welcome aboard ... nice boat.
Air her out good before tabbing - the spark on the jumper could cause a fire ...
Re: New here......
Here is one listed near me but it doesn't look to be anywhere near as good of shape as yours. Congrats on the new Trojan
http://www.lauderdalelakesmarina.com/pr ... eh=3410570
Re: New here......
Can someone tell me where the thru hull valve for the toilet would be because I found one valve but it has a warning of a fine and this looks like the inlet hose to the toilet just Leary of opening it with that plaque attached to the floor next to the valve ? I just need to know if that might be the inlet for the toilet
Re: New here......
Could be outlet for the Lou, a three way valve. Not supposed to dump poop in water unless several miles off coastal shores. On lakes usually is supposed to be secured in off so you wont be tempted to dump.
Re: New here......
Does anyone have information about the emergency power parallel switch and distribution box on this trojan boat. I need help understanding the charging system. Do not know if the switch works but the power goes to a grey box between the engines mount on the transom and then connect to the engines?
