Trojan 1983 F32
Re: Trojan 1983 F32
It is a right turn as many F32 owners have confirmed on the other thread . on the shaft did you check the alignment when the old trans was in ?
fishernut
Re: Trojan 1983 F32
Post by fishernut »
[quote="rossjo"]Be sure to check that the old impeller hasn't ripped any blades off. If blades are missing, be sure to blow them back (backflow the system with low/medium pressure water to push them out), or they will plug things up and cause overheating when you run the engines at speed ...
Congrats on a great boat![/quote
I've had this issue, how do you back flush?
