Chrysler 318, 360, 383, 400, 440 Distributor
Posted: Sun Apr 09, 2017 1:07 pm
Important information if you change out your stock distributor for a new electronic distributor on a 318, 360, 383, 400 440 Chrysler
A non Marine distributor for Chrysler 400 or 440 will not fit unless you remove the cast iron thrust collar.
The purpose of that thrust collar is to hold the oil pump drive gear down on the reverse engine, it is not really need at all on the standard rotation engine.
On the RH engine the collar holds down the distributor drive
Without the thrust collar the distributor drive gear moves upward and in time will wear the cam gear and distributor drive gear and one will break sending tiny cast iron parts through the engine. We have seen this happen and the iron shavings jammed the oil pump.
Basically you have 2 options for the reverse engine. The correct marine electronic ignition distributor I believe it is a Mallory YLM 5000AV or, have a collar made for the distributor shaft that will act as the cast iron collar.
If you text us we will send you a picture of what we use as a distributor shaft collar. I think we have some in stock.
Anyway, do not put a auto distributor in the reverse engine without the correct distributor or a distributor shaft collar
Beacon Marine
609 713 4602
Beacon Marine
609 713 4602
