110V AC
lunkerbasserfishing
110V AC
Post by lunkerbasserfishing »
Wire recommendation for 110V outlets on 76 F26 ?
Re: 110V AC
must be STRANDED not solid
Re: 110V AC
14/2 plus ground, stranded
Re: 110V AC
Post by Paul »
Big D wrote:14/2 plus ground, stranded
+1
lunkerbasserfishing
Re: 110V AC
Thanks to all.
Re: 110V AC
+1 on the stranded.
Our 1975 F36 has a lot of solid wire that looks to be original, so worth a check. I am slowly going through it and replacing with tinned marine stranded wire with crimp lugs. Check out http://www.bestboatwire.com as a potential source of appropriate wire.
Re: 110V AC
Post by Paul »
+1
If you replace the wire from the inlet to the panel, be sure to use something a little heavier like a 12/2 stranded.
Re: 110V AC
If the vessel's service is 30 amps (30 amp inlet/cord), it needs to be 10/2 plus ground from the inlet to the panel.
