1981 F32 water tank problem
fpawn
Post by fpawn »
As I try to fill the fresh water tank there seems to be a blockage at the top of tank. I took hose off to first check and that was fine. After I secured on hose and put floor back, still same problem.. Is there some kink of back flow valve at top of tank?? Any ideas??
Tanks
kallen
Re: 1981 F32 water tank problem
Post by kallen »
Check the vent at the top of the tank
fpawn
Post by fpawn »
Thanks. Going to try that in the morning. Hope I can get to it without lifting floor again!!
ken64k
Post by ken64k »
You could try putting a vacuum hose to the outside of the vent and see if you can clear it out or put a water hose to the vent. With the vacuum you won't be pushing any dirt or what ever into the tank.
Trojan F32 Flybridge 1975
Twin Ford 351s
Albany N.Y.
The water tank vent termination on our 78 was inside the boat attached to a support just behind the removable coaming panel Stbd side......only vents in the hull were gas tanks and holding tank.I can't imagine why you don't want to lift that back deck again.... :P
fpawn
Post by fpawn »
I am not lifting it, n
my son is!!!!
Ahhh, so the deck is voice activated!
