TriCabin /Trifly History
The Tri Cabin was made in Canada at the Trojan facility of Shepherd Boats. She started out as a 36’ Sea Raider Tri-Cabin which was a fiberglass hull, teak forward deck, side decks, aft deck and deck hatches. The cabin top was wood covered fiberglass. The engines were located in the aft state room with Walters V drives 1969 -1971.
1972 she became the F-36 Tri-Cabin model 440 all fiberglass with a teak aft deck and Flybridge top. Engines were located in the aft with Walter V drives.
In 1976 the Tri-Cabin Flybrige model came into production known as the Tri-Fly model 360, V drive configuration.
1978 - 1979 the production of Tri Cabin 440 and the Tri Fly 360 were moved to the Lancaster, PA plant. The teak decks were replaced with a all fiberglass deck.
The 440 became the 361 and the engines were moved from the aft state room to under the salon becoming a straight drive boat.
The 360 Tri Fly remained a V drive boat with engines and V drives in aft cabin.
There were several configurations on the Tri-cabin Model 361, 363, 364, 365
The last Tri-Cabin and Tri-Fly was around 1989.
Tri Cabin / Tri Flybridge
- Beacon Bob
- 00490A76-ECE4-45FC-A02C-8BA8C4BB0528.jpeg (130.43 KiB) Viewed 60522 times
- 86A30AD6-296A-4DF3-A5E8-92EC873AACC0.jpeg (73.72 KiB) Viewed 60522 times
- A9A3444A-59AA-42EB-925C-058AEBEF3897.jpeg (193.87 KiB) Viewed 60522 times
- E8BB9C7F-6F35-44A8-9F89-518C5CEE4930.jpeg (251.85 KiB) Viewed 60522 times
- 493991F0-84F2-42D7-9E67-F00F4CB83F8C.jpeg (209.27 KiB) Viewed 60522 times
