Onan 6.5 marine generator – Completely rebuilt. This was the generator most commonly installed by Trojan on their F-boat and International models. We believe it is one of the best marine generators ever made. This marine Onan generator comes with a heat exchanger for freshwater cooling. ** Generator comes with a one year warranty **
New intake valves, new fuel lines, new gaskets, new spark plugs, all new wiring in the control box and in the tail end, new condenser, new 316 stainless bolts used for reassembly, new relays and resistors.
Oil pan has been removed and all bearings have been checked. All new gaskets, new Onan carburetor, new electric choke, new bolts and nuts.
Starts on first push and puts out 120/240 volts. New Thermoid high temperature hoses, new impeller in the raw water pump and new fresh water pump. New spark plugs, new points, new condenser, new high temperature switch on exhaust, new exhaust elbow and new fuel pump.
6.5 kW @ 1800 RPM -- Single Phase -- 12V Battery -- 120/240V
Store Link: Onan 6.5 Marine Generator
Price: $4800.00 plus Shipping
Onan 6.5 Marine Generator - For Sale
- Beacon Don
- onan-6-point-5-top-view-supplemental.jpg (46.41 KiB) Viewed 87805 times
- onan-6-point-5-switch-view-supplemental.jpg (34.36 KiB) Viewed 87805 times
- onan-6-point-5-wiring-box-view-supplemental.jpg (40.93 KiB) Viewed 87805 times
- onan-6-point-5-side-view-supplemental.jpg (45.51 KiB) Viewed 87805 times
- onan-6-point-5-side-opposite-view-supplemental.jpg (46.68 KiB) Viewed 87805 times
