Water backing up in toilet while going down the lake
When we are docked we have no issues at all. We have the purasan system on our f44 Trojan but when we start out moving around the rear toilet fills up with water. It does not overflow it just fills up to the top. The easy way I found to remove the water is to cut the sea water valve off n push the button to flush n it goes back to normal level. Need help before the big mess happens. Thanks
Re: Water backing up in toilet while going down the lake
Maybe an issue with the vented loop if you have one.
I followed the lines and yes it has the loop in the line
The valve in it could be bad
Replaced the joker valve n no more issues. Thanks
Great news
