Water Leak
Posted: Mon Sep 27, 2010 10:08 am
by Abro
Hello, We purchased a 1988 10.8m sportfish this year. Everything has been great so far ( knocking on wood as I type that ). I am trying to find a water leak that has me stumped. In the galley, where the floor begins to conform to the outside, there is a crease in the floor. This crease tends to get wet, but from where, we do not know. I have checked all the obvious things. Sink, plumbing near by, hot water heater, ice maker, I can not find anything. We thought it had something to do with the AC, since it didn't happen in the spring, only started in the summer, with the AC running pretty much no stop, but this weekend, no AC, and the water came back. Does anyone have any suggestions? I have a picture of the area in question, but can not figure out how to upload.
Thanks in advnce.
Kevin
Posted: Mon Sep 27, 2010 9:57 pm
by RWS
try sprinkling some baby powder around the area to establish some "tracks" to the source.
Posted: Mon Sep 27, 2010 10:05 pm
by thelast322
Is there any possilbility the water is coming from under the flooring? Is there access under the bilge area to check to see? Does it happen after it rains or all of the time?
Posted: Tue Sep 28, 2010 9:54 am
by Abro
I have yet to find a pattern. Rain, no rain, a/c, no a/c. There is an access near the area, but that is bone dry.
Posted: Tue Sep 28, 2010 4:50 pm
by k9th
Send the photo to me and I will post it for you. I know a photo will help me visualize what is happening.
k9th@yahoo.com
Posted: Wed Sep 29, 2010 8:24 am
by rooferdave
check your side window(s) on my boat there is a metal upright separating the two sliding units, the scews holding the metal in place come loose/rot etc. When it rains water comes through the screw holes but does not manifest in the cabin but runs inside the wall, when it gets to the floor inside the wall it will get under your flooring. Does this sound like what you have? I will take a pic of mine as the teak is stripped off to repair the hidden damage, it was left off till now to make sure my fix worked.
