Black Airpax toggle switches ???
Sea Play'n
Post by Sea Play'n »
I am looking for a few black Airpax toggle switches as used in the DC electrical panels on the 11 Meter International series. They are unque in as much as they provide CB protection as well as switching capability. They were made and color coded in ratings from 5 to 20 or 25 amp.
Thanks, Hugh
george petty
airpax switches
Post by george petty »
go onto http://www.airpax.com and they list all the different switches they make and who has stock. the switches you are looking for are the t11-2- what ever amp size. It is a very simple site.
Sea Play'n
Hi George,
I tried http://www.airpax.com and get an aviation software site.
Hugh
george petty
airpax
sorry it should have been http://www.airpax.net
george
rossjo
ANCOR
Post by rossjo »
ANCOR makes a similar switch - won;t atch 0- but very goo dquality. This is all I use.
Be careful with these.
In my 10 Meter, these switches ase actually the CIRCUIT BREAKERS. many of which had been replaced with plain toggle switches by the previous owner rendering NO PROTECTION to the circuit, appliance or the wiring, which could result in damaged wiring and possibly a fire.
I replaced all the missing or aging, cracked breakers with new and am very pleased with the results.
Try John Leed at Marine Tech for replacement breakers.
Sea Play'n
airpax toggle switches
I had no luck with getting these switches anywhere but on ebay. I got 3 double pole, 5 amp for under $5 and 3 single pole 11 amp for $40. I needed them even at the higher price.
Hugh
