loose exhaust hose sinks 36 tri cab
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
1977 F-32
1974 F-25 (Sold)
1979 F-26 (sold)
That suks!!!! I worked on a salvage boat last year..... they're never the same.
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Exactly right............ if the batteries were hooked up. If they were disconnected (doubt it) Wouldn't be too bad.mpulsev10 wrote:Salt Water tears up everything, would have to replace every wire/electronic in the vessel. Fresh water is no where near as bad.
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
exhaust hose
how would having the exhaust hose disconnected at the engine cause it to sink?
That's way above the waterline.....
Re: exhaust hose
If you laid the hose down in the bildge, then it's lower than the outlet of the exhaust at the hull. Passing boats causing a wake condition, over time, no bilge pump to keep up, will defintely sink the boat.BobCT wrote:how would having the exhaust hose disconnected at the engine cause it to sink?
What Jammie said +1
I have seen one in my marina about 20 years ago... guy was doing some engine work on it. Disconnected a few things then left it for a few days as he was waiting for parts. He lifted the exhaust hose up and sat it on top of one of the risers or something... but after a while I guess it tried to spring back to its normal shape and fell off of whatever he had it propped up on. Happened throught the night; people found the boat sitting on the bottom the next morning.
My earlier post I mentioned a salvage boat last year. She sank because the DIY owner thought my price for replacing a muffler was too high. The dummy couldn't get get the muffler loose from the hose so he cut it off with a sawzall. Then when he tried to install the new muffler the hose was too short. In disgust, he left the hose on the bilge floor that evening. She sank! (TFB)
BTW..... insurance would not cover because it was total error on the owner.
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Was it a searay? Ron
