I have recently purchased a Trojan F32 and the previous owner had the Fly Bridge removed and had the deck and wheel house recored and fiberglasses. However I had the boat transported with the Fly Bridge off and am in the process of tracing and checking the wiring, so far so good, however I have located and wired up the Stern Light but for the world I can't see any Port and Starboard lights up forward. Could someone send me a picture showing the location of these lights and also the Anchor light.
Also to check the wiring behind the dash would I be best removing the lower helm wheel or trying to get at the wires from the side panel on the companion way?
Many thanks,
Ian
Navigation Lights
Your front nav lights are just in front of the second bow rail support .( from the front ) mounted in the same area as the bow rail.
the anchor/front white running lamp mounts to the front of the flybrige its on a pole right at eye level . this from the factory , could have been moved because it is a poor place to be ( first thing I did to my boat)
Re: Navigation Lights
They should be VERY obvious forward just under the rail, unless the Prev Owner moved them ( I did).mak'nem wrote:... I can't see any Port and Starboard lights up forward. ...
Many thanks,
Ian
You can get to some wires from the side panel. I have a panel in the galley as well (standard?) as well. I've never taken my lower helm cover off.
Welcome to the forum Mak
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
