lettering removal and bilge heat
I've used a heat gun to remove the letters but there appears to be a glue residue left. On motorcycles I've used wd-40 to remove the glue and elbow grease. I did a quick search but only found oven cleaner and I am scared of both the oven cleaner and wd-40 on the gelcoat. Any ideas?
Also, the boat is in the marina for the winter and I've been checking it daily for ice in the bilge and general well being but is there a better way to keep ice out of the bilge? A guy in the slip beside me suggested a 100 watt bulb but I was scared of gas fumes and the potential for spark from the bulb. again...any ideas?
________________________
1975 F-36
1993 Pro-Line center console
1975 F-36
I used goo-gone pro. From HD. Works good if the oven cleaner worries you.
boatsafe heater in my f32. but i still check on my boat alot but thats also a good excuse too.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
- Location: Mt Juliet, TN. Percy Prist Lake, Fate Sanders Marina
When I first joined the forum, I was concerned also about the winter and the engine freezing up, and at the time new nothing about winterizing an engine.
After posting a question and getting chewed out about putting a bulb in the bilge for fear of gas fumes I bought the Boatsafe bilge heater.
It worked great all winter. It cost an arm and a leg, but it did the job. There was one problem though I had all winter,,,,,what if the power went OFF!
This winter I found out how to winterize an engine, very easy really, but I'm also using the Boatsafe heater,,,,,,just in case!
http://www.boatownersworld.com/boatsafe ... eaters.htm
I see others put up web sites, but will add this one too.
Larry
Larry
