I have a bad sending unit in one of my tanks. I want to replace it this spring. Its a single wire sending unit (origional). Question is it appears its screwed into the tank and has a sealant on it. Anyone know what type of caulk you would use on the gas tank, or is this a rubber gasket? Seems like a black caulk to me.
Seems like a silly question. 3M 4200 says not recomended for direct contact to gasoline.
Fuel Sending Unit - Question
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
1975 36' Tri Cabin
"Keep it up!"
Lake Erie, OH
Make sure the sending unit impedance is a match for your gauge or it will not work properly (ie 33 - 240 ohm). Not all are the same. Perhaps one of the Tri guys knows which one you need to match the gauge.
My senders were 0 to 90 ohm came with the gasket VDO.
the 6 #10-32 screws were NASTY to remove had to work them all the way out working under the sink
36 trojan tri cabin
http://s1116.photobucket.com/albums/k57 ... ?start=all
