oil
Your going to get 30 answers. Mine is 15 40 wolfheads syn-dino blend. Useit in my FedEx trucks. Works fine in my 454' s.
15w-40 dino ( non synthetic ) would be my choice and has been for years gas or diesel boats . I use Rotella right now but would be just as happy with penz , valvoline blue or most any major brand. In fact its time to buy about 8-10 cases again
Synthetic or a blend ?IMO save your money , But if it makes you happy go for it . it won't hurt other buying it .
Tax right-off
Thats what Many OEM are recommending now , and I have been using it in my last 5 boats The only inboard I would not use it in is a Detroit Diesel ( 2 cycle ) total different animal
Other choices are 30w or in real hot weather 40w ( not 10w-40) 15w-40 was not around when your engine was new but it is a good choice . It will cover any temp you will run into in this area striper fishing in Jan or Feb or running down the bay in august heat . Year round it will work
Its what I would use no question
For what it's worth, I use straight 40 weight non synthetic in my '79 with Chrysler 360's.
My engines (gas) are 30+ years old, built with 30+ year old tooling and have over 1600hrs of wear and tear on them. With straight 30 weight, I notice more oil lean and/or burn than with the 40 weight.
Synthetic oils and multigrades are much newer technology. Newer engines are likely finer tooled, closer tolerances, and may have even been designed with multi-weight or synthetic oils in mind.
For old school engines, I am sticking with old school oil technology.
- vabeach1234
I use Mobil 1 10W-30 full synthetic in my LM318.
The manual "Chrysler Marine Engine V-8 Marine Engine Operating Manual" states the following:
"SAE 30 should be used when the anticipated atmospheric temperature will be above 32 degrees, SAE 20W in temperatures below 32 degrees. SAE 10W-30 oils may be used to ambient tempertures as low as +10 degrees."
"Non-detergent or staight mineral oil should never be used"
I'm not staying what to use, I'm just stating what the manual I have for my engine states.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Hampton, VA
- Muskokan345
Like others here, I`ve always been under the impreassion that a single grade oil is the way to go. Read somewhere once that multi-grades contain detergent which is bad for marine engines, never really understood that. Maybe someone higher up the payscale could explain it to me. Plus, I`ve always owned boats 20 to 30 years old, maybe that has something to do with it.
1986 F26
