water tank gauge - fresh water
BobCT
Post by BobCT »
Has anyone added a gauge to the freshwater tank? On a mid cabin, even better.
Rather than drill a hole in the top of the tank, does anyone make a gauge that measures the pump output.... similar to a flowscan?
If I knew the tank was full and could see how many gallons were pumped that would be good enough for me. That way, I wouldn't have to mess with a tank fitting.
I bought a unit a few years ago for my waste tank. But haven't installed it...yet. On poly tanks, you can use the gauge unit on the outside of the tank with remote monitoring.
http://www.sealandsanitation.com/Practi ... arison.pdf
http://www.snake-river.org/
what Jamie said
BobCT
Post by BobCT »
nice, I didn't know these existed. On the mid cabin, the "tank" is actually part of the hull and made of fiberglass.
I'll have to investigate whether the sensors will work on a non poly tank.
larglo
Post by larglo »
Wouldn't a simple "gas" gage setup work? Place sending unit in the tank, gage where ever, and wa-la!?
From what I can tell, it's a lot cheaper way to go too, at least for me, of course.
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
A fuel sender will rust and a water sender should be prety cheap and cheaper in the long run as it will last longer ( and you won't get rusty water ) , The type that go on the sides of the tanks are nice as you don't to drill/ cut the tank.
Some times saving money , will cost you more in the long or even short run.
larglo
Post by larglo »
Your right,,,,never thought of rust!
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
BobCT
Post by BobCT »
I don't think I have many good options. The outside tank strip needs to go from to bottom and I don't have that access.
The sender screwed in through the top won't work either because the tank is a "V" and where I would mount it would bottom out well before the actual bottom of the tank.
larglo
Post by larglo »
I may have been right on my idea after all. Here is a web site that says their sending units can be used for water or fuel.
http://www.twinsrecreation.com/fs75767.html
I have also found other sites that their systems are used for fuel, water, and even waste.
I may even look into one myself as they are not as expensive as first though, at least mot all of them.
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
larglo
Post by larglo »
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
Larry they do make multi use senders , But still should not use a "fuel sender " thats just made for fuel
g36
Post by g36 »
heres what i installed in my f32. i opened the digflow unit and took the sensor and extended the 4 wires to the display. i mounted the flow sensor in the water line just past the pump and put the display in the galley. the meter will do more than what you or i want but it is made for water and is easy and cheap to install. it was a cheap alternative to some others i had looked at. if you want any furthur info let me know
http://www.waterfilters.net/Digiflow-80 ... meter.html
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
I have used stuff from WEMA http://www.wemausa.com/ Old sender stopped working, managed to swap out for a new sender that was compatible with the gauge prev owner (or perhaps factory?) had already installed.
Tank is the original fibreglass tank in my F32.
Bubbabuda
Post by Bubbabuda »
I agrree with Captainmaniac, WEMAUSA is the way to go. I purchased the SHS model sensors and gauges for water, gray water and holding tanks. Great quality, fast shipping.
g36
Post by g36 »
guys the bob ct original poster did not want to drill into the tank to install a sensor
"Rather than drill a hole in the top of the tank,"
i also considered this
https://www.watercounter.com/wc2
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
