sliding glass door f-36
my sliding door to salon does not want to slide, I think it has lost a wheel or it has a flat spot on one....How do you get the door out to check or replace slider wheels? I cant push it up high enough to get it off track and out? anyone had this prob.???
I think Bob sells the wheel kits here ( http://www.trojanboats.net )
Underneath the slider is a molded aluminum piece that has 4 screws holding it in. When you remove the screws, pull the piece towards you - The door will come off with the piece (might need 2 people for this one). When its off, pull the long aluminum bracket off to expose wheels. Get the right wheels!
