Run Dry impellers?
AndyF32
Run Dry impellers?
Post by AndyF32 »
Has anyone tried running the "Run Dry" impellers? I have Crusader 270's with what I believe to be the sherwood E35 pumps and was thinking of trying the Globe run dry impellers. Any opinions?
The only time I worry about the run dry aspect is during winterizing when I am feeding antifreeze into the sea strainers and is is hard to keep up with the pumps.
I had good luck with them on a 671 DD I had And sold then years back with no complaints I remember .
I would still not recc to run any pump dry
AndyF32
Post by AndyF32 »
Thanks for the info.
I have no intentions of running them dry it is just when winterizing I cannot pour as fast as the pumps pull the antifreeze from the sea strainers. I am sure the pumps do not get dry but are just not fully flooded at times.
aaronbocknek
Post by aaronbocknek »
anti-freeze is a lot more slick than water and as long as you don't let it run too long, you should be okay. at least that's my take on it.
aaronbocknek@gmail.com
