Sherwood E35 pump question
Posted: Mon Dec 03, 2012 10:31 pm
by AndyF32
Is 1/16 to 3/32 of radial movement on a sherwood E35 pump reason for a full rebuild kit? Both pumps have about the same amount of play and the bearings seem to spin fine.
Thanks in advance for the help.
[/img]
Posted: Mon Dec 03, 2012 10:43 pm
If the bearing sounds ok ,not a dry sound or rumble then you should be ok a this pump uses a single ball bearing . the shaft goes in to the rear cover/bushing that stabilizes the shaft . If your not sure the bearing is only about $20 , so it not a big deal .
Posted: Tue Dec 04, 2012 8:21 pm
by AndyF32
Thanks for the reply. I will install new impellers in the spring and look at them again in a couple of years.
