77 Tri cabin fwd bilge pump location
Posted: Fri Aug 30, 2013 3:27 pm
by kenflyer
77 tri cabin-Where is the fwd bilge pump? I found the aft bilge pump. I took up the fwd bed cushions and wood supports but did not find it under there.
thanks...Ken
Re: 77 Tri cabin fwd bilge pump location
Posted: Fri Aug 30, 2013 8:46 pm
by blair
Hey Ken,
On my '79 the forward bilge pump is found under the floor area, directly in front of the drawers in the middle of the v-berth. If you pull the carpet back, right in front of the forward heater, you will find it there, I think...unless a '77 is alot different than a '79.
bp
Posted: Sat Aug 31, 2013 5:00 am
by aaronbocknek
if you look in your v-berth locker or the hanging locker on the starboard side, fwd stateroom, you should see the pump discharge hose. follow the hose to the pump. on my tri, a 1982 model, the pump is right under the cabin sole between the steps and the fwd head door. i made an access hatch because the PO covered it up with carpet
. now, on my folks 1972 tri, the pump was in the fwd cabin, between the v-berth. and yes, dad also had a hatch made for gaining access to the pump. so look around. you will find it. and let us know.
aaron
