How to access back of dash on '73 30' Sea Raider?
Posted: Sat Jul 05, 2014 2:58 pm
by drjohn71a
I think I may have some corrosion or loose wiring to my gauges, but can't see how to access the back of the dash. There's a narrow closet between the head and the dash back. The top screws just loosen a mounting panel on top.
How do you get to the back of the gauges?
Re: How to access back of dash on '73 30' Sea Raider?
Posted: Mon Jul 07, 2014 9:41 pm
by larryeddington
wish someone could help you. I know my 77 f28 a panel in the bath has to be removed to service. in my 78 f28 the panel has a piano hinge at bottom and tilts toward the wheel which need to be removed to get full access. But it is not a 73 Sea Raider.
Posted: Tue Jul 08, 2014 11:13 am
by drjohn71a
Thanks, Larry. The piano hinge on my boat tips out a fuse block, well below the gauges. The three Phillips screws on top remove a top plate for instrument mounting.
The head closet is directly behind the dash, and very narrow - no removable panel visible. Maybe the entire closet is removable?
Maybe the stainless trim slides off to reveal another seam. I just don't want to break anything figuring out the proper entry.
Posted: Tue Jul 08, 2014 9:54 pm
by larryeddington
I can tell you from experience, nothing, nothing is easy to work on on a boat! Other than a hangover.
