I can't breathe !!! Exhaust problems
wolfnnj
Post by wolfnnj »
Hey all,
I am having a major issue everytime I used my boat my exhaust whips up into the boat and I or at least one of my passengers chum the water on every trip. I have tried various combinations of windows and hatches opened and closed, the only thing that seems to work is going 1500 rpm with no trim so the tail pipes are somewhat under water but then I can't see where I am going, or I have to run at near (WOT-100rpm)wot to outrun the cloud of gasses. My co2 detector goes off constantly while cruising. I am fed up! This happened with my 318 as well as my new 350. I believe that the engine exhausting in the middle rear of the boat is a design flaw. How do I extend the exhaust to the bottom of my transom so that it doesn't kill me? PVC ?
1971 F-26 Express HT
1971 F-26 w/ 350 Crusader and Paragon PV-31 V-drive.
1968 MFG Westfield w/ Evinrude 50
gitchisum
Re: I can't breathe !!! Exhaust problems
Post by gitchisum »
The port circled in red was the location of exhaust outlet on my 77 f-26. You will want to run wet exhaust hoe all the way to the outlet. Not sure if you have a diffrerent location.
Even this location, I suffered the same "station wagon effect" issue you are having. Needed a stiff cross wind to keep it clear!
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
wolfnnj
Post by wolfnnj »
My exhaust is under the E & W in your picture.
gitchisum
Post by gitchisum »
I would think it would have a better opportunity to clear the transom, if it was closer to the edge.
Not certain what is involved in inner structure from a 71 to a 77. Can you reroute and cut a new hole, glass in the old?
wolfnnj
Post by wolfnnj »
Since I have oversized tanks I would have to pull the motor to accomplish an inside relocation. I was thinking about a toilet flange and some PVC piping on the outside with brackets secured to the transom
BarryL
Post by BarryL »
I have seen similar boats with the exhaust that has a down pipe on the outside that is shaped to cut through the water but is well below the water line and the exhaust gasses come up a fair distance behind the boat and don't have a chance to catch up to boat. Google "Fresh air Exhaust for some ideas and make something up that attaches to current exhaust outlet and is supported by swim platform and you will be good to go and much safer for you and your passengers
Barry
The Dog House
Post by The Dog House »
BarryL wrote:I have seen similar boats with the exhaust that has a down pipe on the outside that is shaped to cut through the water but is well below the water line and the exhaust gasses come up a fair distance behind the boat and don't have a chance to catch up to boat. Google "Fresh air Exhaust for some ideas and make something up that attaches to current exhaust outlet and is supported by swim platform and you will be good to go and much safer for you and your passengers
If adding an extension to route the exhaust underwater, make sure there is a relief hole above the waterline so the exhaust has somewhere to go when the boat is idling.
Former boat: 1971 Trojan F26
Post by Paul »
The Dog House
What about keeping the hatch open to force fresh air through the cabin? I'm thinking about using three rubber blocks (port, center, starboard) to support the front of the hatch (open about 2 inches) along with tightening the hatch handle. Any reason why this might be a bad thing to do?
2024 Gold Support
2024 Gold Support
It sounds like your exhaust is not in the standard location. Makes me wonder why someone would have changed that!
In any event, with a forward hatch open (and any windshield opening ports you may have) you should get enough ventilation through the cabin and cockpit to deal with the station wagon effect. Try running with this configuration (hatch and windshield opened) into the wind. If you still get fumes, they may not be coming from the transom... maybe you have a problem under the cockpit flooring that is the source.
If people are ralphing on every trip it's a definite health and safety hazard, and something to get figured out and fixed before you take anyone else out!
