36' tri cabin
Posted: Fri Nov 07, 2014 10:08 pm
by zipcity1
I have a 1976 tri cabin. have couple of questions. cant get my 12v interior lights to work, is there a master switch? when I turn on sink water pump at switch on panel, red light blinks and pump clicks. does tank need to be full for pump to activate? also. I have removed rear toilet, how do I work the large blue valves below salon floor that go to holding tank, do both need to be open? thanks for any help.
Re: 36' tri cabin
Posted: Sat Nov 08, 2014 9:45 am
by larryeddington
my interior lights did not work on my F28. Traced it to simply a bad fuse. A fan was running off the same circuit and when all on caused overload. Bought a new fan, and change bulbs to LED Festoon type for low current draw. Replaced bad fuse and voila. :D
Re: 36' tri cabin
Posted: Sat Nov 08, 2014 11:36 am
by gitchisum
My F32 has master switches for just about everything ( see left side of panel in picture) This is an 88' so don't know what to expect on 76
Re: 36' tri cabin
Posted: Mon Nov 24, 2014 9:19 pm
by rickalan35
Zipcity - did you solve your problem?
Re: 36' tri cabin
Posted: Mon Nov 24, 2014 11:15 pm
by bjanakos
gitchisum wrote:My F32 has master switches for just about everything ( see left side of panel in picture) This is an 88' so don't know what to expect on 76
Is that your switch box over the dinette? Mine is in the same place, but on the other side under the helm.
Re: 36' tri cabin
Posted: Tue Nov 25, 2014 9:32 am
by gitchisum
bjanakos wrote:Is that your switch box over the dinette? Mine is in the same place, but on the other side under the helm.
Finding out I may have a "only one like it"
Story that has been explained to me is the boat was ordered with no lower helm ( Bar configuration ) and at the last minute a change order was made for a lower helm. Seems I have an international series lower station also.
They must have switched things around a little. ( I am up in Kewaunee if you ever get that way. )
Re: 36' tri cabin
Posted: Tue Nov 25, 2014 9:56 am
by bjanakos
Thanks... I may take a trip up to sturgeon bay next year.
Do you do any fishing? I understand you guys had a great season.
Re: 36' tri cabin
Posted: Tue Nov 25, 2014 9:51 pm
by gitchisum
Fishing is pretty much all we use the boat for. Our season was good, and September was wide open. ( you guys left some Coho's for us!!! ) Pretty much every trip was limits as long as we could get out.
