1971 F31 hardtop trim tabs
Posted: Sat May 02, 2015 1:43 am
by Dcibby85
hey all,
I have a 1971 F31 hardtop express with what I believe are the original trim tabs, they consist of what I would call a worm gear mounted to the inside of the transom with a rod that extends out the back. The further the rod comes out the more it pushes down on the tab. I'm hoping someone can tell me what company made this system or better yet if there is any kind of replacement motor for them seeing how both of mine are Missing in action. Thanks
Re: 1971 F31 hardtop trim tabs
Posted: Sat May 02, 2015 8:08 am
by Lou
I have the F31 Flybridge with what appears original trim tabs & motor. It's a larger motor, I believe I have the book on it. When I get back from Florida I'll see what I got hoping to help you out.
Posted: Sun May 03, 2015 7:53 am
by Tabman
Dcibby85 wrote:hey all,
You quite possibly have the original Bennett electric Tabs.
Here are a few (poor quality) photos:
Do they look like that?
We used to have the electric motors for them, but I will have to check to see if we still do. If you think this is them contact me at
Tabmanhelp@gmail.com and I will look into the replacement motors for you.
Tom McGow
Bennett Marine
Posted: Sun May 03, 2015 8:28 am
I haven't seen a set of those in many many years . Lou I bet yours are the newer type .
Tom "Tabman" , its it worthwhile fixing those old style tabs or would it be better up grading ?? I guess that may depend on the contion of the rest of the system and the motor cost .
Dcibby85 how is the condition of the rest of the system ? inspect it good. I know Tabman will look out for you .
Posted: Sun May 03, 2015 9:50 am
by Tabman
Prowler,
As you suspect it really depends on the condition of the rest of the system. I recall the part number for the old motors, but don't know the price or if we even have them any more. I will check with the factory Monday morning. If the gear case, Tabs, switch and wiring harness are all there and in good shape it might be worth fixing them up.
If not it really is time for a new system!
Tom
Bennett Marine
Posted: Sun May 03, 2015 10:49 am
by Dcibby85
Those look exactly like my tabs. the tabs and gear case are all in great shape and work when operated with a screw driver, the harness and switch panel are still there but will more than likely be replaced if and when I find motors for the tabs. The other question I had was if there is supposed to be some kind of bushing or adaptor that that would go between the motor and the gear housing. I appreciate all the help and information, I've been a full time technician at a marina in Iowa for 11 years now and this is the first time I've ever encountered these tabs so I'm a little bit "in the dark" on them!
Posted: Sun May 03, 2015 3:24 pm
by Tabman
I don't know about the bushing or how the motor was attached to the gear box. We stopped making them about 40 years ago
I do recall that the motor shaft is about 1/4" (maybe a little less) and has a slot in the end of it to engage the gears. I will ask if we have any scanned photos on Monday (I don't think we do).
Tom
Bennett Marine
Posted: Sun May 03, 2015 8:25 pm
Lou wrote:I have the F31 Flybridge with what appears original trim tabs & motor. It's a larger motor, I believe I have the book on it. When I get back from Florida I'll see what I got hoping to help you out.
Lou , you have hydraulic trim tabs . Saw your boat today but you were not around , boat looks good . Came in by boat btw
Posted: Mon May 04, 2015 10:38 am
by Tabman
We checked and we no longer manufacture the motors for that system and unfortunately do not have any supporting documentation on the system.
Tom
Bennett Marine
