looking for a 400 cid chrysler standard rotater
Posted: Mon Aug 03, 2015 8:35 pm
by jimbo36
Through a rod on my starboard (standard rotation?) 400 CID Chrysler engine yesterday.
Anyone have a line on a long block? short block or good used engine? I am in Midland Ontario.
Thanks.
Re: looking for a 400 cid chrysler standard rotater
Posted: Thu Aug 06, 2015 9:21 pm
by Reel Easy
Jimbo. There is a 70s 400 on Akron Oh craigs list asking $250. If its stock the block should work for you.
Posted: Thu Aug 06, 2015 9:55 pm
by Reel Easy
Another thought. You could call musclemotorsracing.com they have built race engines for me and they are top notch. They only deal with Chrysler products and I'm sure they could help you. They are located in northern Michigan.
Posted: Wed Aug 12, 2015 9:19 pm
by Bob Giaier
Once you start the job it would be great to see some pics on how you removed and replaced the engine especially if yours are under the rear beds as mine are on my 73 Tri cabin
Posted: Fri Aug 14, 2015 11:01 am
by Barrie
Hey this just showed up on kijiji
http://www.kijiji.ca/v-engines-and-engi ... nFlag=true
I need a couple myself, but not yet.
Posted: Sun Aug 16, 2015 6:50 am
by Big D
Posted: Sun Aug 16, 2015 5:59 pm
by jimbo36
Thanks Big D, I tried Kawartha but will try the other. Barrie, I looked at this motor and discovered there are 2 400's. This is a car engine and it looks like I need the truck engine 400B.
Posted: Sun Aug 16, 2015 9:45 pm
by Barrie
My understanding is there was only one 400 block, crank, rod, piston engine.
I've been messing with Chryslers for 30 years. You should be able to use the short block and add all your externals and your good to go.
I could be wrong but I've never heard of any other 400 block
The B block is for the big blocks 383, 400 and some other older big blocks 318 etc.
The RB is raised big block most commonly 440 for a taller stroke.
Barrie
Posted: Mon Aug 17, 2015 12:53 am
by Reel Easy
Barrie is 100% correct. Car, truck, boat , crane, generator, motor home all the same parts. IMHO if I were to build a pair of b block mopars I would use factory spec bottom end and a good set of heads. All marine specs. Very dependable and powerful.
Posted: Mon Aug 17, 2015 8:41 pm
by jimbo36
Reel Easy wrote:Barrie is 100% correct. Car, truck, boat , crane, generator, motor home all the same parts. IMHO if I were to build a pair of b block mopars I would use factory spec bottom end and a good set of heads. All marine specs. Very dependable and powerful.
I have since discovered you guys are right, one 400 CID. Someone who I would have expected to be an expert gave me wrong information.
