POSITION OF SHAFT ANODES
Posted: Mon Apr 25, 2016 11:18 am
Hi, I have a F32 and was wondering where my shaft anodes should be placed.
Call BEACON MARINE @ 609-713-4602 -- For QUICK answers to your Trojan questions
https://trojanboats.net/wforum/
Mine are further ahead, but I guess your setup does double duty -- if the shaft coupling ever lets go, the anode will stop the shaft from being pulled out...Big D wrote:You're likely to get a variety of opinions on this but a few good marine electrical books that I've read indicate very close to the front of the strut, like about half an inch or just under. I always place mine half an inch away.
Yep, but it's more about electrical flow and protection of the shaft and prop, and the rudder and post as in both cases, dissimilar metals are in contact with each other so you want an anode as close as possible. I suppose you can move the shaft anode a little further forward if you had rudder anodes but what would be the point of moving them further forward. I've also read that anodes further forward can influence the balance of the shaft and induce a wobble under the right conditions. While it may not be noticeable, it can be measured. When it's very close to the supporting point of the strut, the possibility of throwing off the shaft's balance becomes negligible.captainmaniac wrote:Mine are further ahead, but I guess your setup does double duty -- if the shaft coupling ever lets go, the anode will stop the shaft from being pulled out...Big D wrote:You're likely to get a variety of opinions on this but a few good marine electrical books that I've read indicate very close to the front of the strut, like about half an inch or just under. I always place mine half an inch away.
I can see the argument re balance.. if the anode is off balance and mid way between stuffing box and strut, it can cause maximum problems. Closer to the strut, it has less potential of actually throwing the shaft off.Big D wrote:Yep, but it's more about electrical flow and protection of the shaft and prop, and the rudder and post as in both cases, dissimilar metals are in contact with each other so you want an anode as close as possible. I suppose you can move the shaft anode a little further forward if you had rudder anodes but what would be the point of moving them further forward. I've also read that anodes further forward can influence the balance of the shaft and induce a wobble under the right conditions. While it may not be noticeable, it can be measured. When it's very close to the supporting point of the strut, the possibility of throwing off the shaft's balance becomes negligible.captainmaniac wrote:Mine are further ahead, but I guess your setup does double duty -- if the shaft coupling ever lets go, the anode will stop the shaft from being pulled out...Big D wrote:You're likely to get a variety of opinions on this but a few good marine electrical books that I've read indicate very close to the front of the strut, like about half an inch or just under. I always place mine half an inch away.
One would think so but I have not found this to be the case in the field. Too many variables involved including the electrolyte (the water you're in) If you measure, you'll find a difference in potential the closer you get to your props and rudders, that's where I want a sacrificial anode to be. The further away you get from there, the less worrisome the measurement becomes. Prop nut anodes used to be more popular than they are now but there was a reason why they put them back there. New Gen Bravo III drives have prop nut anodes now and they have anodes all over them including an electronic impressed current cathodic protection system at the transom assembly. Even with this feature, several other anodes are still a must throughout the drive. The drives are aluminum of course but it serves to illustrate that if you were to simply add an anode to the transom in the general vicinity, the electrons wouldn't bother traveling the additional foot, they'll simply take the path of least resistance.captainmaniac wrote:.....Electrically though....electrons are electrons. Whether they have to migrate 30' or 32' to find a grounding victim, they are going to do it and do related damage. I would think a properly installed anode should do the same job no matter where it is along the shaft.....
