Lots of little questions
Posted: Sun Aug 21, 2016 8:43 pm
I have started working Miz B myself! A big Ca-ching happens when the Marine guys come out - and they don't come out when they should.
So, a few weeks ago you all helped me with a wiring diagram when I thought my electrical system was shot as the breakers kept braking. I was able to take the breakers out, drive 50 miles to a big boat guy - and he said - it's your air conditioner! Yup, rooftop air is busted.
So, called Marine fix-it guy a month ago, sure, put it in in two weeks. Four weeks later - no A/C. So - the width of one of the windows above the stairs JUST fits one of those 6000 BTU Frigidaire window units if you put it on a little box to miss the curves. Runs super quiet, plugs in up top. Ta-da!
1) Now, to my first question - when I yank out the roof-top A/C - , I am supposed to have a 14 X 14 hole. Can I install this http://www.etrailer.com/RV-Vents-and-Fa ... SP-28.html - vented roof-top fan, 12V - comes with a battery because I don't think the 12V wires are up there. It's 14.25 X 14.25, so a little filing, it should work, right?
2) Second question - the temp gauges downstairs don't register, on top they register perfectly. Would it be smart to assume it's the gauges and replace them? I think I can get to them in the little cover in front of the lower berths.
3) Third question - same location, the Hummingbird Depth Finder registers like 450', 500'. I think maybe someone stepped on it and it's measuring the shoreline. Can I follow the lead down to the bottom of the boat somewhere and see what the problem is?
And, I have one solution! My grinder in the potty broke and I read somewhere that a person thought it was overkill to have a grinder, etc. and to have to drag the boat down to have it pumped, etc. so he got a porta potty. Thetford has a new, really streamlined porta potty that snaps on to a floor plate, is very stable and the right height. The other potty unbolts and is one enclosed piece. So, I bundled it off the boat and stored it, just in case. The Thetford fits in the same spot and looks like the old one. So - I had one contribution to all this. http://www.thetford.com/product/porta-potti-curve/
Any and all help would be appreciated. I figure I am now about $2400.00 to the good and with a boat, that never happens. Christi
