ignition start toggle switch
Posted: Tue Sep 27, 2016 10:58 am
On my tri-cabin one engine kept cranking even with ignition switch off. Melted terminal on battery. The problem was the solenoid/start switch on the starter, in fact the engine started and starter engaged and running caused the rotor wires to heat up and flex outward contact the stator destroying both. That is being rebuilt. I decided as a precaution that I would change the actual toggle switch and the start relay under the 50 amp breaker.
I began the search for our ignition toggle switch - off-on-mom. I finally found them at Grainger for 11.63 each:
Carling 10C581 which appear to be exactly what we have.
As soon as I pickup the rebuilt starert all will be well again.
