power supply
lasker
power supply
Post by lasker »
i show this on my power supply....red light on the left with reading pegged to the right...on right gauge shows working...i unplug shore power and red light goes off..but gauges stay the same...could i have a polarity problem?
1979 321 Trojan
2024 Gold Support
2024 Gold Support
Re: power supply
i asume shore power ? Are you using bothe cables ? Check the voltage to make sure you not getting 220 on one side and check the polarity .
lasker
Re: power supply
Post by lasker »
using both cables and all outlets are on and working..headers, hot water,etc no sign of 220
1979 321 Trojan
lasker
Re: power supply
Post by lasker »
1979 321 Trojan
2024 Gold Support
2024 Gold Support
Re: power supply
Did you check with a volt meter on the boat and on the dock ? That should be the first thing . You can get a polarity test at a hardware store and check polarity of the outlets . Have you tried swaping the cords at the dock ? Does the issue change sides ?
Re: power supply
heres a cube style polarity tester
Should be 1 on every boat
cost $10
https://www.amazon.com/Receptacle-Teste ... NrPXRydWU=
2024 Gold Support
2024 Gold Support
Re: power supply
RWS wrote: Wed Mar 17, 2021 6:41 am heres a cube style polarity tester
cost $10
Exactly !
Re: power supply
I'll see your polarity tester and raise you a volt meter. Also serves to trip GFCIs, if you're into that kind of thing....
https://smile.amazon.com/gp/product/B08 ... UTF8&psc=1
Re: power supply
lasker wrote: Tue Mar 16, 2021 12:29 pm.....i unplug shore power....but gauges stay the same..
At minimum you need new gauges.
lasker
Re: power supply
Post by lasker »
It was new gauges...
1979 321 Trojan
Re: power supply
Do you have the cross tie switch and if so is it in the right position for both cables connected ?
lasker
Re: power supply
Post by lasker »
cross tie switch?
1979 321 Trojan
Re: power supply
lasker wrote: Mon Mar 29, 2021 11:21 am cross tie switch?
There was an option that allowed you to power up both sides of the panel when only one shore power cord was connected. The breaker /switch was one of those lower ones on your 120 panel.The switch had to be in the correct orientation when both cords were used. Just a thought as it used to throw me if I wasn't watching. As I remember those polarity indicators were a bit on and off on our boat and I replaced the volt meters a few times.
