F32: water tank location
It seems bizarre that I cannot find the 40 gallon fresh water Fiberglass tank, but I can't, and the owners manual does not give a location either. So... who can tell me, in layman's language? And thank you!
Re: F32: water tank location
What year and model ? Several models and changes througt the years . Early tanks where Gal . Have you traced th fill to the tank ?
1986 is the year.
The fill can be seen in the lazarette but then it goes forward through the bulkhead and I lose sight of it. thx
- Beacon Bob
The F-32 water tank is in the aft between the two fuel tanks.
If it has been changed just follow the water fill. Generally the water fill hose goes directly to the fresh water tank.
The F-32 had a 40 gal fresh water tank.
