Engine runs colder than I thought
TADTOOMUCH
Post by TADTOOMUCH »
After looking at a previous post about low oil pressure, I got to wondering about my F-32 and the water temp reading lower than what I thought it would.
I run in Lake Michigan and the warmest I can get the engine to run is about 130 to 135. I have new gauges, sending units, and thermostats.
When I winterize the engines I can get it up to 160 for a while with the antifreeze solution recirculating through the system.
I thought that after she warmed up under cruise, that she would run closer to 160 once the thermostat opened up but, she runs no warmer than about 130 or so.
Is this normal?
Oil pressure is stable and within specs at prescribed rpms.
Everything else seems fine and the water pump works well and manifolds are all in the same temp range when running.
I've checked with some others in my marina and their boats run closer to 160 but are not Trojans.
What do you guys think?
Boat Name: A TAD TOO MUCH
Post by Paul »
Sounds normal to me for an open cooling system. My 350 Mercruiser also has a 140°F thermostat and runs in the 135°F to 140° range. A closed cooling system with a heat exchanger would normally run hotter with a thermostat rating from 160° to 180°.
If you have an open system and find that your engine(s) run much hotter than the thermostat (160° with a 140° thermostat) this usually indicates some type of problem such as a restriction, blockage or lack of water supply.
Hope this helps.
gjrylands
Post by gjrylands »
I also run in Lake Michigan with raw water cooled engines. Like yours my engine temperature is 130. This is normal and my engines run great.
Closed systems run hotter.
Gerry
1979 F36 Twin Chryler 440's
jddens
Post by jddens »
My F30 with 350 merc's and closed loop with heat exchanger run at 160.......about right for closed loop...........
1998 Kawasaki ZXi 1100
Your fine
LandVF36
Post by LandVF36 »
Our F36 with open system cooling of twin 454s runs about 130-140 as well. We're on the Mississippi south of Minneapolis where the river water temp ranges from the 50s in the spring, near 80 in August and back to 50s by the time we pull her for winter storage.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
rossjo
Post by rossjo »
Might want to check with an InfraRed temp gun - you can get a hobby model for about $50 - and know exactly what your temps are ...
Post by Paul »
Captain Ross's suggestion is a good way to check your entire system from the pump to the mufflers. Keep in mind that if you ckeck it with an infrared thermometer that external engine temperatures are always a few degrees cooler than your actual coolant temperature. This is due to heat dissipation on the surface of the castings. The best place to verify what the gauge is reading is just below the thermostat.
