synchronizer - how important
On the F32 I just purchased ...the engine sync. is not working. I never had twins before, so I'm not familar with using it. Any thoughts? Replacement?
Often tachs are unreliable - one may read 50 rpm high, the other 50 rpm low, so matching them up means nothing. An engine Synch is helpful but not critical because you can synch the engines up by ear. If they are out of synch, you can usually hear a bit of a droning pulsing sound (because of the difference in the harmonic frequencies of the engines). The further they are out of synch the faster the pulse sounds; the closer they are, the slower the pulse sounds. When the pulsing sound disappears both engines are 'humming' along at the same freqeuency, and you are synched !
You might have to listen a bit to hear the drone, but once you do try slowly advancing one throttle and see if the pulses speed up or slow down. If it slows down, you need to advance that throttle a bit more or pull back on the other one. If the pulses speed up, do the opposite.
Good luck.
Good luck.
Like Captmaniac said, I sync by ear. The tachs will never be identical and there will be a difference in rpm most likely.
I'm amazed at how even my friends will run their boats out of sync. They are surprised when they hear the difference after I show them how to listen for the tune of the engine. After a while, you'll get the hang of it.
Enjoy...
Enjoy...
My sync works great. I was new to twins so it was great in training my ear. I still use it but mainly because it's on the flybridge and that's the only place I operate the boat from........and it will show you that your tachs ARE not prefect........
1998 Kawasaki ZXi 1100
