10 meter port holes
10 meter port holes
Hi everyone! Its Ron with my first question .(of many i am sure!) I need to repair or replace port holes on my 84 10 meter. One has a broken trim ring on the outside,can it be repaired? and three need hinges and lock hardware on the inside and i also want to replace all of the seals(gaskets). does anyone know if i can get these parts? or what has anybody else done. any info will be apreciated.
Slippery When Wet
84- 10meter
84- 10meter
Bob @Beacon Marine or John @ Marine Tech
There were two versoins of these portlights.
The earlier one was a simple flat tinted lens with six thumbscrews on the inside. This one hasa simple gasket available that ca be easily replaced.
The later models had stainless frames.
Which International had the 6 thumb screws on the inside? I have never seen one.RWS wrote:
perhaps it's less... I'll have to check next time i'm onboard.
It's FOUR plus the hinge, not SIX.
