was thinking if this would work?
carverman
Post by carverman »
i got a 1982 33ft carver with twin 440's in her however no gen..
well i've got this batt.. charger and inverter coming from bob we ordered.
however i just got a 2000w honda gen. and i was wanting to know couldn't i just make up a small pig tail from gen to shore plug in at the end of my boat. .. to JUST power up my 110 side of things like coffee pot ,maybe a fan or two. i mean the thing doesn't give out 30amps so was thinking it would just place power to the 110 on the boat am i right ?
or would it do anything wrong to my boat?
CARBON MONOXIDE ACCIDENT WAITING TO HAPPEN
9rock
Post by 9rock »
put a generator shore power switch in before the panel
this will protect the inverter when on shore power from burning up
9
wire inverter/charger as-per instructions and you should be ok. just make sure you don't short cut anything.
RWS wrote:CARBON MONOXIDE ACCIDENT WAITING TO HAPPEN
I agree , I have always felt a portable gen set has no place on a boat. But if your going to use one anyway the safest place to put it is on the swim platform exhaust pointed away from the boat ,and no open thru hulls near by .
As far as wiring get a 15 to 30 amp adapter and use your shore power cable
carverman
okay thats what i needed
Post by carverman »
you all helped out alot .i won't do that idea ,i just was thinking about it ,.and needed your input on it thanks
Rodman
Post by Rodman »
Have any of you guys seen the Honda`s 2000 run? These gens do not put out a lot of sound or exhaust fumes. I do not see any problem with this unit being paced like on the swim deck if you want to use it when the boat is sitting still. These are very small units your exhaust from your boat will put more then this little unit will ever put out. That unit is so quite its unbelievable.
Trojan
ready123
Re: was thinking if this would work?
Post by ready123 »
carverman wrote:however i just got a 2000w honda gen. and i was wanting to know couldn't i just make up a small pig tail from gen to shore plug in at the end of my boat. .. to JUST power up my 110 side of things like coffee pot ,maybe a fan or two. i mean the thing doesn't give out 30amps so was thinking it would just place power to the 110 on the boat am i right ?
Nothing wrong with your plan of taking the output from the Honda and inputting it into your shore power 30 A plug on the Carver.
You just need a 30A to 110 V connector which you should have anyway for the chance you stop at a small Marina without 30 Amp service.
Of course location of the Honda exhaust is key, try and keep it outside the hull and close to the water line for safety. When I had my Bayliner and no genny that is what I used... often placed it on shore as the vibration from the swim platform became a little annoying over time.
It will do no harm to your shipboard electrics... just be aware that when you try to draw more than the Honda's output you will have to reset it.
foofer b
Post by foofer b »
Get a coupla CO detectors
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
ready123
Post by ready123 »
Does every boater not have at least one CO/CO2 detector even if they do not use a portable Honda :?:
I would certainly hope so... along with a gas sniffer in the engine room if fuel is gasoline :!:
I would bet most do not .
foofer b
Post by foofer b »
Best $29.95 you can spend.
MY CURRENT FLEET
mr elevman
Post by mr elevman »
bolth co2 and gas sniffer bolth installed be for fist launch 3 years ago preves owner had neither and no fire extinguishers now thairs 4 including the fire-boy in the engen comcartment
ready123
Post by ready123 »
mr elevman wrote:bolth co2 and gas sniffer bolth installed be for fist launch 3 years ago preves owner had neither and no fire extinguishers now thairs 4 including the fire-boy in the engen comcartment
Everyone should respect boating like that!
TC
Post by TC »
When you put that genny on the swim platform tie it to a cleat. That may seem very obvious but it wasn't to a friend of mine last summer. He borrowed ( oh oh ) a Honda 2000 for holidays and put it on a towel !!! so it wouldn't scratch the platform ( gulp can you see it coming? ) Well it's now in 30 feet of water.
Worst thing, he had to pay for a generator.......and he still doesn't have one.
1989 F-32
Penetang,
Georgian Bay
