Photos of V drive and Strut
Rodman
Post by Rodman »
Trojan
foofer b
Post by foofer b »
That does not look like mine.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
vabeach1234
Post by vabeach1234 »
Looks like mine except mine are blue.
I got this info off of a google search for Paragon V-Drive Ratios
PV 31 - 1:1
PV 32 - 1.5:1
PV 33 - 2:1
I have the PV31.
Here's a few pictures when from when I replaced the engine.
http://i853.photobucket.com/albums/ab96 ... C00144.jpg
http://i853.photobucket.com/albums/ab96 ... C00142.jpg
Those pictures were taken back in 2006. Man, it's amazing how 4 years of marine environment will rust up somethings.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Rodman
Post by Rodman »
vabeach1234 wrote:Looks like mine except mine are blue.
PV 31 - 1:1
PV 32 - 1.5:1
PV 33 - 2:1
I have the PV31.
Thats is what I have is P31-1 so it is a 1:1 ratio
Trojan
looks like the 14 x 10 was close maybe with some cup ? when you get some numbers with ther gps we may know more
foofer b
Post by foofer b »
Rodman, does your engineface rearward? You know with the drive belts toward the stern end of the boat?
MY CURRENT FLEET
foofer b
Post by foofer b »
It must face rearward cuz the exhaust is heading toward the stern, hence the "V" drive. Was that the original configuration in these? Anyone?
MY CURRENT FLEET
vabeach1234
Foofer,
Yes, the paragon V-drive was the original setup for the at least the 1972 F26 model. I don't think there were many changes between the 71 and 72 models. [/code]
Ken
Hampton, VA
Rodman
Post by Rodman »
vabeach1234 wrote:Foofer,
do you have any photo`s of the inside of your cabin? And helm What prop are you using on your boat what size engine do you have?
Trojan
Rodman
Post by Rodman »
foofer b wrote:Rodman, does your engineface rearward? You know with the drive belts toward the stern end of the boat?
The front of the engine faces the stern. Your engine faces bow doesnt it ?
Trojan
vabeach1234
Rodman,
Sure do.
http://s853.photobucket.com/albums/ab96 ... nditioner/
http://s853.photobucket.com/albums/ab96 ... jan%20F26/
http://s853.photobucket.com/albums/ab96 ... %20Galley/
I am currently in the process of installing a marine air conditioner so no more door mounted air conditioner. When done, I'll start a new post for that.
I have a Chrysler 318 225 hp with a 3 blade - 14x10 RH prop. FYI, she's no speed boat. Cruise is about 16 mph, top speed so about 22 mph at 4000 rpm. Chrysler wot is 4000 fyi. Your ford might be higher.
Ken
Hampton, VA
Rodman
Post by Rodman »
vabeach1234 wrote:Rodman,
Sure do.
Yea we have same model. Is the roof of the galley fiber glass?
Trojan
vabeach1234
Yes, the ceiling of the cabin is all fiberglass. Or should I say, fiberglass-balsa core-fiberglass.
Ken
Hampton, VA
Rodman
Post by Rodman »
vabeach1234 wrote:Yes, the ceiling of the cabin is all fiberglass. Or should I say, fiberglass-balsa core-fiberglass.
I think we have some nice boats. My f25 has the cloth on the ceiling. I like how ours have all fiber glass through out the galley.
Trojan
Post by Paul »
Rodman,
Looking at the first picture in this post of your prop & strut, I noticed that you have the prop nut and the jam installed in reverse order. In this application the thinner jam nut should be installed first followed by the larger nut. When the last nut is installed and tightened, it takes the load off of the first nut installed and since the larger nut has more thread area its better suited to accept this load.
