My '77 F-26 did not come equipped with a seacock on the water inlet (the original invoice says this was a $40 option at the time of purchase...) It has a bronze strainer and fitting to a straight pipe, connected to the inlet hose off a 90 degree elbow. The lack of any water shut-off on this most vulnerable point has me thinking I can replace this the "easy way" by fitting an in-line ball valve between the inlet and the engine supply hose by mounting this valve on the current inlet fitting. Is there any pros and cons I need to know about or should I just install a seacock when the boat is pulled for the season?
Seacock or In-line ball valve for F-26 - Need advise
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
Phosphour bronze
You should be more worried about the old through hull falling apart when you touch it.ask any welder. Put in a new one and be secure...
F36 ~
SHES SOLDDDDDD
SHES SOLDDDDDD
Yep, they are that. Mine had a soft spot on the starboard bow deck - took care of it from the inside, but one of these days I'm going to do a better job of it. I've updated the plumbing, bilge, electrical, battery capacity, etc and the engine is in great shape. The lack of the seacock AND strainer between it and the engine intake makes me glad the boat's been on an inland freshwater lake! Taking it on the Erie Canal next summer so want to get more updates done before then.
Best
Best
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
Well
Luck being what it is - now that you have identified a problem - it will probably go wrong!
No reason to gamble with your boat. I would do both - short term fix and long term solution, but not wait itoo long.
You may ruin the fitting trying to "fix" it now - and be up s**t creek (at at the bottom of it), so make sure it is really solid before messing with it.
Good luck my friend!
- jon_e_quest
randyp: RE: 7/17/07 post: While an in-line ball valve will accomplish the task of shutting the intake water off if needed, the combined ball valve-on-top-of-the-thru hull installation is taller than a proper seacock installation (which is screwed directly to the bottom of the boat), and could snap off if accidentally struck... probably at the exposed thru-hull threads.
It costs more, but a seacock is designed and built for the task.
Current Boats:
1962 18' Chris Craft Cavalier
Former Trojans:
1972 F-36 Tri-Cabin
1976 F-26 Express HT
1978 F-25 Express HT
Former Trojans:
1972 F-36 Tri-Cabin
