Hey gang,
‘Twas Monkeying around today in the boat, and I happen to notice I’m missing the starboard side shaft key. Judging by my port shaft, the starboard shaft looks to have pulled away from the coupler a tad. Can anybody be walk me through repairing this, and/or sourcing a new key?
Boat is still in water at my pier.
‘74 F32 318’s
Shaft key missing
Shaft key missing
- C90F6787-8B51-4A2A-965C-8A466A16C9DE.jpeg (121.49 KiB) Viewed 4053 times
- 8731631A-6452-473A-9401-D594482AF4C8.jpeg (119.69 KiB) Viewed 4053 times
Re: Shaft key missing
Is it still lined up ? I would probe and see if the key is just up in the coupler a bit .
Prowlersfish,
Excellent call. Looks to be still there. Should that shaft be further into the coupler? I know it may be difficult to say solely using the “eye test”. Ive never seen an unassembled shaft/coupler setup, so I’m clueless about all of this.
Thanks again
Thanks again
- 75431795-2163-49CF-8025-E6665A1C3037.jpeg (64.68 KiB) Viewed 4049 times
Looking at the key way I see no sighs of movement , Hard to tell looking at the shaft , I don't think so . Mark the shaft and key a eye on it . Shaft will pushed forward in forward and back out in reverse if it is loose . You can look at it in the slip but you won't be able to put a full load on it ,
Thank you for your guidance.
I went ahead an marked both.
Can’t wait for spring—already tired of the winter blues!!
