Thin nut first and here is why
http://www.boltscience.com/pages/twonuts.htm Watch the video
Prop nuts thick or thin first
- twonuts_jammed.gif (16.1 KiB) Viewed 5213 times
Re: Prop nuts thick or thin first
thanks prowlersfish
I found that fascinating, although I doubt many others will.
Do you have any more info on what method is best for resisting vibration?
Lock nut, lock washer, any combination of the two, etc.?
rr
rr
10 meter mid cabin
I think that would vary on application. In many cases lock washers/lock nuts are not used and sometimes just washers. Engines head bolts you will never see lock washers but sometimes regular washers. Look at your all bolts on your engine how many places do you see lock washers? Now, look at your shaft couplers bolts always lock washers or lock nuts. Over the years I have found and repaired many loose couplers. And most had lock washers. Yet that was not the cause. The use of SS bolts and or course threads or both was the cause. SS stretches and course heard does not clap as well. Always use grade 8 or better fine thread bolts on couplers. I also prefer lock washers .
Look under why nuts and bolts come loose
https://www.boltscience.com/pages/info.htm?
more good info
https://www.boltscience.com/pages/faq.htm
- P-Dogg
The search box may help you with an answer even before Prowlersfish can:
http://www.trojanboats.net/wforum/viewt ... 4&start=15
I'll take the U.S. Navy's word for it........
Did you watch the video? I found it interesting.P-Dogg wrote: ↑Mon Sep 12, 2022 9:33 pm The search box may help you with an answer even before Prowlersfish can:
