Need some help?
Hitman46mod8
Need some help?
Post by Hitman46mod8 »
So I have an 83 Trojan Tri-cabin. Absolutely love it! However I have an issue. I was going to change out the lights in the V-berth, fwd head, kitchen over the stove, and rear head shower. I had already changed the salon lights to LEDs. I'm thinking no big deal. So I took some measurements of the existing lights and ordered a set(5) led single 12v R.V. ceiling lights. I went to wire them in, the first light didn't turn on. So I tried another one, same issue. So I got out my dvom and I measured 6.8v at the port V-berth light. I took measurements at the fwd head and kitchen light. 8.2v fwd head. 8.4v kitchen. So I was hoping someone could possibly post a wiring diagram or the under helm label number for this circuit. I'm assuming I have a dirty connection or some bad wire somewhere, I need a place to start troubleshooting. Any help would be appreciated.
83' F36 Tricabin
5.7L Crusaders
Re: Need some help?
Is battery voltage ok on both batteries? Check the breaker connections and the breaker itself and grounds. Do you have the wiring diagram?
Re: Need some help?
I should note many times on Trojan boat wiring black can be positive. I just reread your post you don't have a diagram. Every trojan is unique. But you can get one for your boat from Beacon Marine. They also have complete owner manuals for your boat.
Best to give him a call.
bob@beaconmarinesupply.com
Hitman46mod8
Re: Need some help?
Yes prowlerfish, the batteries are topped up. Breakers are good, and I checked voltage from the salon circuit, I'm aware of the black positive wiring. Good info for anyone reading. I guess I will purchase a Manual from Beacon's store. Thank you for responding.😁
83' F36 Tricabin
5.7L Crusaders
larryeddington
Re: Need some help?
Post by larryeddington »
changed every bulb to led with no problem, must be the wiring
