v berth mattress
v berth mattress
78 f32. looking to make sleeping a bit more comfy has anybody had a v berth mattress made? still using what is probably the original cushions to sleep on and i would like to get a better nights sleep than present. we spend alot of overnights and think its about time. like to get a few thougths from you guys on this. thanks
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
- ready123
Any furniture repair shop should be able to do the work. Give them your old ones to use as templates so they can match the outside curves in both L & V directions.
You should be able to have any options added too. I had them use HD foam with a 2" topping of memory foam and I selected the fabric for them to use as the cover. Micro fibre cover with vinyl on the bottom to ensure I don't get any condensation into the foam.
Very comfortable sleep.... the new ones were at least 1 1/2" thicker....
- Stripermann2
A while back, I asked about something along the same lines but modified.
I think it's possible to put a mattress from one side at a 45 degree to the otherside...eliminating the two halves and making one double sized mattress. Maybe not...?
http://www.trojanboats.net/wforum/viewt ... h+mattress
My family spends alot of weekends in our boat and the original v berth cushions were not comfortable. My wife ordered a king size memory foam mattress cover, must be at least 2" thick maybe 3", I cut it to fit as one piece over the v berth cushions and it made all the difference. She is making custom fitted sheets for it this winter. Cheap and comfortable.
Jim
Jim
SHEGAVEIN (F-32)
Capt. Jim Jordan
Capt. Jim Jordan
We had all our upholstery recovered in 2004 and had the v-berth cushions made with thicker foam (5 inches best I remember). The old ones ( 3- 4 inches) would let your bones bottom out on the plywood. The thicker foam makes all the difference.
inner spring mattress
We had inner spring mattress s made up for the v berth by Gioia Sails in Lakewood N.J. He makes them himself. Just like sleeping at home. He also made up custom sheeets and mattress pads for us. Give him a call times are tight right now if you need any enclosure or other work done you might be surprised at the pricing . They have a web site http://www.gioiasails.com. No they dont do any sails. He can do anything you need for a boat . phone in N.J. is 732 901 6770. He also has a shop in Florida in Palm Coast 386 446 6650
DUCHESS 1987 F36
